Bon, pour vous faire partager ces instants, les photos devraient suivre ce WE (si le temps le permet...)
Il s'agit donc, d'une Mustang MACH 1 couleur noire production 1611 sur 9652 code R (1FAFP42R73F438322), 6000 kms oui km car elle vient de Quebec.
j'en suis :amoureux: et toute la famille Edo
Elle attend sa nouvelle immatriculation avec les plaques rectangles bien sûr...
Suite bientôt
Edo
PS : merci a ceux qui était dans le secret...
point technique en attendant les photos... :
Engine MOD 4.6L DOHC V8
Displacement 4.6L, 281 cu. in.
Horsepower @ rpm 305 @ 6000 (projected)
Torque lb.-ft. @ rpm 320 @ 4250 (projected)
Compression Ratio 10.1:1
Fuel System Sequential multi-port electronic fuel injection
Fuel Requirement Premium (91 octane minimum)
Exhaust System Stainless steel with chromed rolled tips
Transmission Type 5-speed manual or 4-speed automatic
Final Drive Ratio 3.55:1
Gear Ratios (Manual) 1st - 3.38; 2nd - 2.00; 3rd - 1.32; 4th - 1.00; 5th - 0.62; Rev. - 3.38
Chassis Construction Unitized body
Front Suspension Independent, modified MacPherson strut with Separate spring on lower arm and stabilizer bar
Springs 600 lb Helical coil, rubber-insulated, unique linear rate
Shock Absorbers Integral with Tokico strut, gas-pressurized, Hydraulic, unique valving
Stabilizer Bar 26.5 même (1.04 in.) solid
Rear Suspension Four-bar link with coil springs on lower arm, unique horizontal axle damper and stabilizer bar
Springs 250 lb Helical coil, rubber-insulated; unique linear rate
Shock Absorbers Unique axle damper, gas-pressurized, hydraulic. Vertical Tokico shock absorbers with horizontal axle dampers, unique valving
Stabilizer Bar 23 même solid (.905 in.) solid
Steering Power-assisted rack-and-pinion
Overall Ratio 15.3:1 on center
Turning Diameter, Curb-to-Curb 38.1 ft.
Brakes Front Calipers Aluminum dual piston, custom anodised painted
Rotors 330 même (13 in.) Brembo vented, Rear Calipers Single piston
Rotors 296 même (11.7 in.) Brembo vented
ABS/Traction Control Yes
Pedals : stainless steel pedal covers are positioned to provide better heel-to-toe relationship
Wheels 17 x 8-inch Magnum 500-style "Heritage Style" (5 spoke)
Tires Goodyear 245/45ZR17 Eagle ZR45
