Hello
Quelqu'un aurait une idée pour le back up d'origine sur une ford mustang gt 2011
Le trinity de chez diabolo sport ne veux pas ce mettre à jour temps que le back up d'origine de la voiture ne ce fais pas
Posté 04 May 2015 - 07:37 PM
tu as une "tune" injectée dans l'auto ?
Si oui , il faut que tu fasses un retour stock, tu fais ta mise à jour et tu ré-injecte la tune . C'est une sécurité, en cas de foirade de la Màj, au moins ta cartographie "stock" est à sa place au chaud dans le calculateur ;)
Si non ben là ???
Vincent
Posté 07 May 2015 - 01:58 PM
Trinity Update Instructions
1. Before updating your Trinity, you restore the stock tune to the vehicle. This is accomplished by selecting the original backup option from the Performance Menu of your Trinity.
2. Download the DSDownloader program to your PC from the CD provided with the Trinity or from here on our website: Trinity downloads page
3. Launch the DSDownloader program on your PC once it has been installed.
4. Select Trinity from the tool communications screen then click Continue.
5. Connect your Trinity to the PC using the supplied USB cable.
6. When the DSDownloader finds your Trinity, it will display a message that the tool was found, click Close.
7. At this point, if you have not yet registered your Trinity, DSDownloader will ask you if you wish to register, choose yes, and complete the registration form. If you have already registered, skip to the next step.
8. DSDownloader will query your Trinity to see what revision it is on and what application you have selected. It will then check the website to see if there are any new Full or Incremental updates available for you.
9. A message will be displayed A new full update is available for: (selected application) Clicking OK will download the file from our site automatically.
10. Once the file is saved to your PC, DSDownloader will ask if you would like to send .crom file to tool, choose YES. It will send the update to the Trinity. Once the transfer is complete, the Trinity will reboot.
11. Once the Trinity reboots, click Options/Legacy connect on the DSDownloader, then click Options/Auto Connect. The DSDL will re-query the Trinity and check to see if there are any incremental updates available.
12. A message will appear saying a new incremental update is available for your application, click OK to download.
13. Once it has downloaded, click OK to send crom file to tool.
14. Once the tool reboots, select your vehicle from Options/Change vehicle type, then you may reinstall the Trinity in your vehicle.
If you need any assistance with updating your Trinity, please contact our technical support line at 800.531.5484x1 or on our Trinity support forums here: Trinity Forums
Ce message a été modifié par Mr Stock - 07 May 2015 - 02:00 PM.
Vincent
