les roue de 17''
#21
Posté 18 November 2003 - 08:05 AM
1965-1966 Mustang
15- to 18-inch: All rim diameters use 7-inch-wide wheels with 41/4-inch backspacing and 225-section-width tires up front. Rear wheels are 8-inch with 4-1/2-inch backspacing and 235-section-width tires in the rear except for 18-inch rear wheels, which can use 245/35 tires. Tire aspect ratios for each rim diameter are as follows: 15-inch, 60; 16-inch, 50; 17-inch, 40; 18-inch, 35.
1967-1968 Mustang and Cougar
15-inch: 15x8 with 4-1/2-inch back-spacing and 225/60 tires front and rear for 1967-1968; 1969-1970 can use 15x9 with 5-1/2-inch backspacing and 235/60 tires in the rear.
16-inch: 16x8 with 4-1/2-inch back-spacing and 225/50 tires front and rear for 1967-1968; 1969-1970 can use 16x9 with 5-1/2-inch backspacing and 245/50 tires on the rear.
17-inch: 17x8 with 4-1/2-inch back-spacing and 245/40 tires front and rear for 1967-1968; 1969-1970 can use 17x9 with 5-1/2-inch backspacing and 275/40 tires on the rear.
18-inch: 18x8 with 4-1/2-inch back-spacing and 245/40 tires front and rear for 1967-1968; 1969-1970 can use 18x9 with 5-1/2-inch backspacing and 265/35 tires on the rear.
1979-1993 Mustang
15- to 17-inch: All 15- to 17-inch rim diameters use 8-inch-wide rims with 5-1/2-inch backspacing and 245/55 tires.
1994-2000 Mustang
16-inch: 16x8 with 5-1/2-inch backspacing front and rear. Use 245/55 tires.
17-inch: 17x9 with 6-inch backspacing front and rear. Use 255/45 tires.
18-inch: 18x9 with 6-inch backspacing front and rear. Use 255/35 tires.
#22
Posté 18 November 2003 - 08:06 AM
#23
Posté 11 December 2003 - 08:52 PM
#24
Posté 11 December 2003 - 08:54 PM
:shock: :shock: :shock: what beautiful engine :shock: :shock: :shock:
quel rapport avec les 17 ??
#25
Posté 11 December 2003 - 09:34 PM
#26
Posté 11 December 2003 - 09:48 PM
en tous cas elle tue celle là !!
#27
Posté 11 December 2003 - 10:13 PM
je sais pu se qu'il disait, style
"aucun rapport vec les jantes et c'est surment pas un moteur ford"
no coments
#28
Posté 11 December 2003 - 10:17 PM
héhé, exodus a viré son message.
no coments
No comment ;) tu y est presque ;)
#29
Posté 12 December 2003 - 01:28 PM
Bon, ce qu'il faut voir, c'est que le deport ne soit pas trop important pour que la roue, quand elle debat, passe bien a l'interieur de l'aile. Le probleme de la monte en 18, c'est de trouver des pneux qui se montent dessus sans que la voiture ne soit trop haute sur patte!
P.J.
#30
Posté 10 January 2004 - 11:59 PM
#31
Posté 11 January 2004 - 08:58 AM
#32
Posté 11 January 2004 - 09:46 AM
C'est magnifique.
J'suis love.
:amoureux: :amoureux: :amoureux: :amoureux: :amoureux: :amoureux: :amoureux: :amoureux: :amoureux: :amoureux: :amoureux: :amoureux:
