J ais trouver un petit kit de resto mais je pige rien a l anglais et c est pas mon dico qui m aide pour la mecanique
J aurais besoin d un bon traducteur
1. Fender Bolts & Washers (22 ea.)
1. Deck Lid Hinge Bolts & Washers (8 ea.)
1. Shock Tower Bolts & Washers (16 ea.)
1. Trunk Latch & Catch Bolts & Washers (5 ea.)
1. Gravel Panel Bolts & Washers (4 ea.)
1. Radiator Mounting Bolts & Washers (4 ea.)
2. Hood Hinge Bolts (10)
3. Fender Bolt U-Nuts (20)
3. Hood Latch & Catch U-Nuts (3)
3. Battery Tray Mounting U-Nuts (2)
3. Valance Mounting U-Nuts (6)
3. Gravel Panel U-Nuts (4)
4. Trunk Filler Board Screws & Washers (2 ea.)
5. Shock Cover Bolts (6)
6. Hood Latch & Catch Bolts & Washers (11 ea.)
6. Horn Mounting Bolts (2 ea.)
7. Valance Mounting Bolts, Front (6)
8. Fender to Cowl Bracket Nuts (2)
9. Battery Tray Mounting Bolts (2)
10. Hood Latch & Catch Nuts (2)
10. Horn Mounting Nuts (2)
10. Fender to Cowl Bracket Nuts (2)
10. Battery Tray Mounting Nuts (2)
10. Battery Hold Down Nut (1)
10. Shock Tower Nuts (16)
11. Gravel Panel Cage Nut & Bolt (Replacement) (1ea.)
12. Battery Tray Mounting Bolt (1)
13. Valance Mounting Bolts (4)
13. Headlight Housing Mounting Bolts (8)
14. Valance Mounting U-Nuts (4)
15. Rear Valance Screws (11)
17. Brake Line Mounting Bolts, Under Fender (2)
19. Shock Cover Nuts (6)
20. Battery Hold Down Bolt (1)
21. W/S Washer Bag Bracket Screws (2)
22. Windshield Washer Tee Screws (2)
23. Cowl Weather-strip Bracket Screws (4)
24. Gas Filler Neck Screws (5)
25. Gas Tank Mounting Screws (11)
25. Brake line Mounting Screws (2)
26. Accelerator Pedal Bracket Screws (3)
26. Engine Ground Wire Screw (1)
27. Heater Blower Motor Mounting Nuts (4)
28. Master Cylinder Equalizer Bracket Bolt (1)
29. Master Cylinder Mounting Bolts & Washers (2ea.)
30. Shock Tower to Cowl Brace Bolts & Washers (8ea.)
31. Voltage Regulator & Solenoid Screws (4)
Je sais y a beaucoup :oops: :oops:
